 93C86WQ... which device should I use?
eliotroyano Posted - 01/21/2013 : 06:48:03
Friends, as the title says, I need to read/write a ST93C86WQ 16bits eeprom on board with a GQ-3X programmer and a Pomona clip, then my doubts are:
1.- which device should I use? the exact code is not available in the list?
2.- does I need to swap bites to have a good read or writing again?
Thanks in advance for your help.
Regards,
Eliot
PD: This should be the eeprom --> http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/DM00043901.pdf
15.41 KB
eliotroyano Posted - 01/21/2013 : 17:52:11
I have readed tthe 93C86WQ with a 93C86C-16bit device using the GQ-3X and I think that it dump should be ok. But why does it read with bytes swapped?
