 AM29F400BB
Progman Posted - 02/09/2013 : 09:25:00
Hi
I want to read and write AM29F400BB on the board and can get h**p://www.testpath.com/Items/SOIC-Test-Clip-44-Pin-114-157.htm?gclid=CO-5jNnI5bQCFehDMgod_00A7g to attach to the chip.The only problem is the programmer is compatible for read and write but only got 40 pins and chip is 44.
Can someone just show me how to connect it,I need the wiring plz.
I also need to do TB28F400 but its not supported atm any hope for it in the future?
Progman Posted - 02/11/2013 : 22:55:12
Yep understand that need to remove it.I see there is 2 adapters available which one is recommended. I also need to read TB28F400 that's from the same family of chips but it seems to be not supported any possibility to add it?
ZLM Posted - 02/10/2013 : 09:13:59
You have to remove the chip to do the read and write on the programmer.
Progman Posted - 02/09/2013 : 11:10:42
And to normaly read TB28F400 will it be avail?
ZLM Posted - 02/09/2013 : 09:55:38
This does not work.
You have to remove the chip and program it on the programmer.
Generated in 0.39 sec. Snitz Forums 2000
