 12F508 config bits problem
martin Posted - 03/07/2007 : 20:46:47
Erase function also erases config bits even though I only select "erase code"
Martin
ZLM Posted - 03/09/2007 : 21:04:24
The 12F508's 1 byte cfg uses code area to store it, and it shares same programming command. So, when erase the code, the cfg also be erased. This is not a programmer software bug, it works as designed.
