| T O P I C    R E V I E W |
                | edy-6 |
                Posted - 04/25/2013 : 06:47:40  Hello have a adp TOOL-012 SMD SOIC8 Programming / Testing Clip. does not recognize the adapter? list H / W Re: Re-GQ-3X 1.30 (SW Re. 6:23) USB Driver Re.2.0 Software Re. 6:23 Checking new software on server ... DEVICE W25X40 * SOIC8 SOIC8 W25X40 * << >> Load Unknown command. This software is already updated. SOIC8 W25X40 * << >> SOIC8 W25X40 * << >> ID check failed. ("FFFFFF") Check device type and direction of the Chip on your site. Some chips may be compatible with OEM Chip ID Continue? not ID check failed. ("FFFFFF") Check device type and direction of the Chip on your site. Some chips may be compatible with OEM Chip ID Continue? yes Check ID Saute Reading ... Memory Code Elapsed Time: 274.96 Seconds. Reading Completed.
    103.26 KB |
                | 2   L A T E S T    R E P L I E S    (Newest First) |
                | edy-6 |
                Posted - 04/28/2013 : 18:57:06  hello clg I removed the bios and put the adapter SOIC8 200 thousand but the writer also does not recognize the adp you can see in the picture he read, clean record, but I am in doubt whether he is actually doing the process or not because it detects the adp. lights the burner is lit so vcc / busy - power. (vpp - no lights). does the recorder is in trouble. be able to help me thank you.
    109.7 KB |
                | ZLM |
                Posted - 04/27/2013 : 18:37:49  Try to remove the chip and program it on the programmer with this adapter OR a SOIC8 adapter. |
