| T O P I C R E V I E W |
| caventou |
Posted - 06/07/2013 : 09:56:41 Hello
I have a GQ-4X with a ADP-054 adaptator, i have permanently this error when writing on 27C322 :
Write failed, Address=0x200100, Buffer=0xFF Device=0x45
It happened 3 times with 3 different chips, same message, I suppose my adaptator has a failure because I can write on 27C801 without any issue |
| 7 L A T E S T R E P L I E S (Newest First) |
| LemonyVengeance |
Posted - 01/16/2014 : 10:12:04 I am having this issue as well. I have moved J1 to short pins 2&3, but not J5. I will try that out.
In the past this has worked if I set the speed to 0, but it is no longer working.
I have tried this with 7 Chips, all pass the blank check but fail the write. I have 7 more coming in today that I will test this with. |
| ZLM |
Posted - 11/23/2013 : 17:20:09 Chip is bad? |
| strange |
Posted - 11/19/2013 : 08:10:42 i also have the same issue and i changed J5 both ways |
| caventou |
Posted - 06/13/2013 : 07:01:28 owww my apologies, I thought this adaptator didn't required any jumper, I just saw them...Well it's never too late to learn...
Thanks for your reply, greatly appreciated I'll keep you updated if my trouble is still going on...
| ZLM |
Posted - 06/12/2013 : 22:58:09 There is a 3 pins jumper, set it to left side for V3 and right side for V4. |
| caventou |
Posted - 06/12/2013 : 11:55:19 Thanks for your answer but I don't get how I should switch with this kind of adaptator ?
| ZLM |
Posted - 06/09/2013 : 22:40:05 If you got exact same error, then try to switch the J5 between V3 and V4.
Try to use a 9V external power and see if it works.
