 Totally new to this.
pauldimler93 Posted - 06/25/2013 : 18:59:27
I recently purchased the GQ-4x and the DIP8/SOIC8 adaptors. My first time playing with this machine will be with a 93LC86 EEPROM. What problems will I run into as a novice? It cant be as simple as read/save dump, modify dump, then upload/save it to the chip? Is it? Will I need to remove EEPROM from board before I do anything? anything helpful is much appreciated.
Miguel.I.Fonseca Posted - 07/21/2013 : 12:33:11
If the chip is on a PC motherboard, remove the clock battery, and all cables and cards from the motherboard first. I've noticed this helps in having a good reading and, maybe, it could also affect writing to the chip.
M
ZLM Posted - 06/28/2013 : 13:40:16
The In Circuit Programming is not that simple as you thought. The chip power is connected to all other component. So, the power is the first issue. You may need to study the circuit and find out a way to do the In Circuit Programming.
If you are in hurry to programming the chip, then remove the chip from the PCB and program it on ZIF OR testclips.
