 GQ-4X Target voltage
gaosqq Posted - 07/09/2013 : 05:10:05
When you get AVRISP connection. Is there a possibility to "program" a
5 volts connection to the pin opposite to RST.
I use a dil connector, piece of flat-cable and a standard 6-pin ICSP
connector. (no more empty batteries ..........etc.)
Not native, my Dutch is better.
ZLM Posted - 07/10/2013 : 18:48:51
For the AVRISP, your chip needs a separte 5V power and external oscillator if the external OCS fuse bit enabled.
