 No GQ-4X support for PIC16(L)F1455
pquesinb Posted - 10/09/2013 : 13:49:18
Is there any planned support for the PIC16F1455? If not, is there any third-party software which supports the GQ-4X programmer which might do it?
ZLM Posted - 10/11/2013 : 11:06:42
It seems the browser does not allow us to download .dev file.
I cheanged the .dev to .txt file, try to download the .txt file and change it back to .dev file after you downloaded it.
http://www.mcumall.com/forum/uploaded/zlm/PIC16F1455.txt
right click on the link and select "Save target as" option.
pquesinb Posted - 10/09/2013 : 19:37:45
ZLM,
Thanks for the posted info, but the link you gave is 404. Can you double-check the URL?
Cheers,
- Phil
ZLM Posted - 10/09/2013 : 15:35:53
I think this chip should be supported.
Download this PIC16F1455.dev file into GQ programmer software "device" directory. Example, my directory is "C:\Program Files (x86)\GQ USB Programmer\Devices".
Download Attachment: PIC16F1455.dev
33.5 KB
Added following line into devices.txt file:
Name="PIC16F1455",ID="2927A0",Class="PIC16FXXX",Category="MCU",VPP="9V",WVPP="9V",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="16384",Package="DIP14",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
This device line is not been tested and confirmed. Let me know if it works.
Then you should be able to see it from the supported list.
