 it was a great programmer.... while it lasted
Irvingw Posted - 01/09/2014 : 07:49:42
Good day to all;
I have a GQ-4X programmer, which worked great for the better part of the year. Now, I just get a power light, but the program won't recognize it.
Can anyone suggest a solution here?
Kind thanks.
ZLM Posted - 01/20/2014 : 17:51:21
You can download the RE2.01 driver from:
http://www.mcumall.com/download/TrueUSBWillem/USBDriverV2.0.1_32_64Bit.zip
Irvingw Posted - 01/20/2014 : 11:38:10
I've tried to re-install the USB driver, as it does seem to be corrupted. However, when I access the driver via the control panel, and it gives me the option to re-install.... It asks for a "co-installer", which should be on the disc. Unfortunately, I'm missing the disc, and can't seem to re-create this software install. Any suggestions?
Thanks.
ZLM Posted - 01/11/2014 : 09:43:54
Check the USB driver first and see if the driver is loaded correctly.
See Reply #6 from:
http://www.mcumall.com/forum/topic.asp?TOPIC_ID=2030
