 MX25L1005A verify Failed please help
joelz Posted - 02/08/2014 : 02:10:30
Using adapter ADP-004 SOIC8 (150mm) with MX25L1005A:
Erase - pass!
Blank check - pass!
Write - pass!
VERIFY - Always failed on the same code
"Verify failed,address 0x000000,Device=0xff,Buffer=0x002"
Please help for solution
Craberry Posted - 06/14/2014 : 20:14:24
i have the same problem.. it has the same symptom in slower speed, always problem with verify process..
MX25L1005AMC ----------->> MX25L1005MI (ID check pass, meanwhile using MX25L1005MC -->> ID Check fail)
I already clean the ic pin and the adapter..
Any solution for this problem ?
osvaldo Posted - 02/09/2014 : 12:59:47
fijate memory this good contacts clean ic adapter and if that does not throw that error. if you can look at the data sheet saver memory to the memory id
ZLM Posted - 02/09/2014 : 00:55:32
Does it ID the chip? if so, try slower speed.
