 Problem writing 95080 3 (Really Urgent)
Poloman Posted - 08/18/2014 : 09:27:26
When I try to write either of the two files in the chip it appears the msg on the print screen that I upload. I have chosen every of the three types of 95080:
1)M95080
2)M95080R
3)M95080W
in all three the same msg appears. Do you know the problem? The chip is an ST 95080 3
In the links there are the print screen and the files that I try to write. Thank you for your time. The matter is really urgent, if anybody can help, it will be appreciated very much.
h**p://speedy.sh/XZpKa/95080-print-screen-fail.rar
h**p://speedy.sh/c5ZVT/95080-immo-off.bin
h**p://speedy.sh/8x5ds/95080-ori.BIN
ZLM Posted - 08/19/2014 : 14:49:42
Those chips should be supported.
Try to use slower speed.
If it still does not work, then try to programm other chips and make sure the programmer is good. Such as any other 25XXX or 93Cxxx EPROMs
