 GQ-4X swapping
fadhle Posted - 08/30/2014 : 04:24:03
Hello guys, i have a GQ-4x it is a good programmer, but when i read 93lc66B - 93c66B - 93c46b the reading on the buffer is swapping,why?
but for reading ATMEL25020 & ATMEL25040 it is read ok,
can any one help me to get the right reading from these EEproms,regards.
ZLM Posted - 09/05/2014 : 20:45:07
The GQ-4X software used international standard Little-endian format. So, it is correct.
fadhle Posted - 09/03/2014 : 04:09:16
many thanks to you my friend, i have x prog and top programmer when i read dump it is ok shown in buffer as it is written in the eeprom,how i know after reading by GQ-4x are the data in buffer are swap or not, since not all eeproms that are reading by gq-4x are swapping,
are all gx-4x do like my Gq-4x or my problem in software or in hardware,I install the latest version 6.30,king regards.
ZLM Posted - 09/01/2014 : 09:07:31
That is fine. You can just click the A/B Swap button to swap it back.
The Hi-Lo byte order is depending on programmer software used. As long as your chip works in your machine, then it is not important. The only thing is the data file is not compatible with other programmer software.
But GQ-4X software has Swap button to correct this problem.
