| T O P I C    R E V I E W |
                | khaahk |
                Posted - 01/05/2015 : 03:19:50  Datasheet: h**p://www.nexflash.com/NR/rdonlyres/script5B6C30B-C174-43CF-867E-E1A2F371A07C/0/W25Q128FV.pdf
  Adding the line:
  Name="W25Q128",ID="EF4018",Class="W25X10",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="16777216",Adapter="ADP-081, ADP-027 adapter",Platform="GQ-4X";
  does not do the trick. Shows FFFF as id, reads all FF-s EDIT: must have been bad contact, adding the line helped. Reads OK.
                | 1   L A T E S T    R E P L I E S    (Newest First) |
                | ZLM |
                Posted - 01/13/2015 : 22:00:31  It should work.
  Check your connection. |
