 READING ATMEGA 64 WITH GQ-4X
nikos Posted - 02/20/2015 : 12:24:29
Hello,
I want to read Atmega 64 with GQ-4X, do i need to use lock bits or fuse bits to read it properly, it supports eeprom and flash together.
Regards.
nikos Posted - 02/22/2015 : 04:11:59
can you help me with the procedure to unlock Atmega 64 because i want to read eeprom and flash.
ZLM Posted - 02/21/2015 : 20:46:37
yes. It supports EEPROM and Flash. They are stored in separated buffer and you can loaded them by separate file. You also can read and write EEPROM only manually.
The fuse you can control them separately too.
Generated in 1.18 sec. Snitz Forums 2000
