 Replacement/Repaired GQ-4X failing 27C020's..again
Necrosaro420 Posted - 03/02/2015 : 17:18:37
My 4x stopped burning 27c020's. Sent it in for a repair, which took forever...have had it back several months now, and it's starting the same thing. Is the QC that bad on these things?!?
ZLM Posted - 03/07/2015 : 21:05:30
It is realy weird if it fails again on same chip. It must be something wrong. You need send it back for the service.
Necrosaro420 Posted - 03/03/2015 : 09:54:33
It programmed them fine once I received it back. I have 2 of these programmers. One will no longer burn them, the other will burn them just fine.
ZLM Posted - 03/03/2015 : 00:13:49
If same thing happened, then it must be something else wrong. Is it the problem is exactly same as last time? how many chips you have programmed then?
