 AB28F800 PSOP with DIP44 adapter
iblackford Posted - 04/29/2015 : 19:31:07
Hi All,
I have a 28f800, PSOP, in a DIP44 socket. I also have a GQ-4X. From what I understand I will have to do the following:
-put device in byte mode instead of word mode
-hook up A0-A18 to A0 to A18
My question is where do I connect A-1? Does this connect to A19?
Thanks for any help, Ivan
iblackford Posted - 05/03/2015 : 15:33:52
While I know there is a plug and play adapter, and I thank you for that, I'm asking for instructions on making what I have work.
Thanks, Ivan
ZLM Posted - 04/30/2015 : 18:53:05
If you use ADP-019 from MCUmall, then you do not need to connect any address line.
Only the ADP-019 adapter is needed to connect.
