| T O P I C R E V I E W |
| erps |
Posted - 05/08/2015 : 05:26:15 I have loaded an HEX file with the corresponding File Offset 8000. However, when I check what is in the buffer by clicking on the Code tab, I see addresses from 0000 to 7FF0 filled with FF, but can't scroll down to see from 8000 to FFFF, where the code is supposedly to be.
So when I program the chip, it doesn't do anything because the chip is being programmed with FFs. What I am doing wrong?
Thanks, |
| 4 L A T E S T R E P L I E S (Newest First) |
| erps |
Posted - 05/19/2015 : 08:56:39 quote: Originally posted by ZLM
If you set the file offset in software, then the software load the data starting from 8000. If the data beyond that location, then software will ignore it.
If your file has build in offset 7FFF, then you need to put file offset value to -7FFF, in that case, the software load the data from 000.
It worked by entering the File Offset -8000 Thanks for the tip.
| ZLM |
Posted - 05/14/2015 : 17:58:59 If you set the file offset in software, then the software load the data starting from 8000. If the data beyond that location, then software will ignore it.
If your file has build in offset 7FFF, then you need to put file offset value to -7FFF, in that case, the software load the data from 000. |
| erps |
Posted - 05/13/2015 : 16:24:56 quote: Originally posted by ZLM
The chip only has maximum address up to 7FFF. So, no way to see beyond the that point.
Ok, so what I need to do to see the code between 0000 and 7FFF? |
| ZLM |
Posted - 05/13/2015 : 15:31:50 The chip only has maximum address up to 7FFF. So, no way to see beyond the that point. |
