 E28F320J5
Hernan Posted - 09/28/2015 : 13:31:18
Hi, i need read and reflash E28F320J5,
As I can make with Willem GQ 3x,
I have the ADP-082 adapter, I can change and welding wires instead of using that socket?
thanks in advance
ZLM Posted - 11/10/2015 : 12:09:22
You can try to make an TSOP56 adapter yourself.
Hernan Posted - 11/10/2015 : 04:35:05
Hi. ezoflash suport ? so I can buy or produce it
Hernan Posted - 10/19/2015 : 05:50:03
you can tell me that you can read and write? Thank you
ZLM Posted - 10/01/2015 : 06:38:26
The chip is TSOP56 chips.
The GQ-4X does not support it.
Generated in 1.16 sec. Snitz Forums 2000
