 25l1005amc
paulhm81 Posted - 05/07/2016 : 01:01:19
Hello to all of you!
I need to program a 25L1005amc on a gq-4x rev 2 and i have a problem. The id is seen corectly but it doesn't write. It fail at verify. I read the original contens without a problem then I erased it without any errors but it's not writing to the chip. After it's done writing and gives the verify failed message if I read the chip it is blank. Any ideas? Thank you!
ZLM Posted - 06/30/2016 : 06:15:36
Need to see exact error message.
Also, do blank check before write.
-Arielc72 Posted - 06/29/2016 : 11:48:24
Dear MCUmall, i have the same problem, i have read all post about this problem (MX25L1005AMC), and I didnt see solutions!! Do you have any solutions? Thanks in advance
ZLM Posted - 05/11/2016 : 22:32:26
