| T O P I C R E V I E W |
| Dbob |
Posted - 07/29/2007 : 13:09:10 Hi, I have the FWH/HUB (according to the markings), now I try to figure out the difference vs the FWH/LPC+, since I'm trying to flash a SST49LF004A(B) without any luck.
Any gudance, do I need a new adapter?
/DBob |
| 7 L A T E S T R E P L I E S (Newest First) |
| Dbob |
Posted - 08/09/2007 : 10:57:56 One more computer saved with the TrueUSB + some adapters, not bad !! |
| ZLM |
Posted - 07/31/2007 : 19:53:16 See: http://www.mcumall.com/forum/topic.asp?TOPIC_ID=566 |
| Dbob |
Posted - 07/31/2007 : 12:57:05 To bad I bought the FWH/HUB together with the True-USB when I initialy ordered the burner. I have ordered the LPC+ so it should work in a couple of days.
Anyway, I'm interested in what kind of modification is possible on the FWH/HUB, is there a howto or something? |
| ZLM |
Posted - 07/31/2007 : 10:12:34 Yes. You have to use FWH/LPC+ to program SST49LF004A(B) on True-USB Willem Programmer.
The FWH/HUB parallel version does not work. Unless you do some modification on it. |
| Dbob |
Posted - 07/30/2007 : 22:08:30 Ok, but can anyone confirm that I need the LPC+ adapter to flash on a True-USB, I already have the FWH/HUB which I thaught should handle FWH/HUB eeproms as SST49LF004A(B).
| ZLM |
Posted - 07/30/2007 : 18:32:06 There are differences between those two version adapters.
The FWH/LPC+ adapter supports both Parallel Willem and True-USB Willem. |
| Dbob |
Posted - 07/30/2007 : 09:00:51 I just ordered a FWH/LPC+ adapter.. I hope that was the right decision, can anyone confirm this? |
