 AMIC A29040C
Gagostini Posted - 03/05/2017 : 03:09:15
Hi all. Iīm trying to program an AMIC A29040C flash but this one is not on the device list. How can I program it? I tried with A29040B but donīt work. My progemmer is an USB GQ-3X.
anniel Posted - 03/12/2017 : 13:53:39
Did you try a lower speed?
Gagostini Posted - 03/12/2017 : 09:19:38
I have over 20 chips and all have the same problem. I have achieved to program two of them, but I needed at least five tries.
anniel Posted - 03/05/2017 : 11:36:39
A29040B and A29040C have the same ID. Probably a bad chip if the pins are clean.
Gagostini Posted - 03/05/2017 : 08:21:26
When the programmer checks ID says: "ID check failed.("FFFF") Please check device type, chip orientation and pin contact. Some OEM chips may have compatible chip ID. Continue?"
After pressing "yes" button it says: "Write failed, Address=0x000000, Buffer=0x16 Device=0FF"
I have lots of AMIC A29040B and never failed, but the AMIC A29040C always fails.
anniel Posted - 03/05/2017 : 05:10:00
What is the error message when using A29040B?
