 TC58NVG1S3EA00 and H27U1G8F2BTR in my GQ4X4
elbronco Posted - 01/08/2018 : 10:42:57
Hello, I am trying to read and write these memories TC58NVG1S3EA00 and H27U1G8F2BTR in my GQ4X4 but I can not find them in the list of devices. Can I add them by hand? What would be the parameters?
ZLM Posted - 02/07/2018 : 23:02:17
GQ-4x4 does not support NAND. You need GQ-5X NAND programmer PRG-120.
elbronco Posted - 01/22/2018 : 16:59:40
With what device configuration can I try?
anniel Posted - 01/16/2018 : 04:10:23
Originally posted by elbronco
I can make de attempt? With adaptar 003 tsop48
If you succeed post your device line.
elbronco Posted - 01/15/2018 : 13:06:21
anniel Posted - 01/13/2018 : 05:54:03
For NAND Flash you are better of with a GQ-5X.
elbronco Posted - 01/11/2018 : 12:55:04
Alguna forma de cargar esa memoria al archivo Devices.txt ?
elbronco Posted - 01/09/2018 : 09:34:07
Aren't those Flash NAND?
Hi, I found this info:
The H27U1G8F2BTR-BC is a NAND Flash, it has 128MB x 8-bit with spare 4MB x 8-bit capacity. The device is offered in 3.3V VCC power supply and with x8 I/O interface. Its NAND cell provides the most cost-effective solution for the solid state mass storage market. The memory is divided into blocks that can be erased independently so it is possible to preserve valid data while old data is erased. The device contains 1024 blocks, composed by 64 pages. A program operation allows writing the 2112 byte page in typical 200µs and an erase operation can be performed in typical 2.0ms on a 128kb block. Data in the page can be read out at 25ns cycle time per byte. The I/O pins serve as the ports for address and data input/output as well as command input. This interface allows a reduced pin count and easy migration towards different densities, without any rearrangement of footprint.
NAND Interface - x8 Bus Width, Address/Data Multiplexing, Pin-out Compatibility for All Densities
(2K + 64) Bytes x 64 Pages x 1024 Blocks Memory Cell Array
(2K + 64 Spare) Bytes Page
(128K + 4K Spare) Bytes Block
25µs (Maximum) Random Access
25ns (Minimum) Sequential Access
200µs (Typical) Page Program Time
2ms (Typical) Block Erase Time Fast Block Erase
elbronco Posted - 01/09/2018 : 09:29:33
H27U1G8F2BTR-BC - Flash Memory, NAND, 1 Gbit, 128M x 8bit, TSOP, 48 Pins
h**p://www.farnell.com/datasheets/1605619.pdf?_ga=2.202399761.1045167718.1515519098-1448978438.1515519098
anniel Posted - 01/09/2018 : 06:40:01
