 what am i doing wrong? 93c56
freebandjunkie
Posted - 06/24/2016 :  14:31:57  Show Profile  Reply with Quote
please help, from the beginning. i installed the drivers first then the usbprg program. the adapter im using is a " tool-013a(?) " which is suppose to allow me to program in-circuit but i cant get it to work
im running windows vista 64-bit (emulated on vmware)
what am i missing?
pix
http ://i66.tinypic.com/11rfxnk.jpg
http ://i66.tinypic.com/2llhafq.jpg
http ://i68.tinypic.com/2yn5tau.png
Posted - 06/24/2016 :  15:58:12  Show Profile  Reply with Quote
What is the version of the driver and software?
freebandjunkie
Posted - 06/24/2016 :  16:00:28  Show Profile  Reply with Quote
provider cypress
date 6/22/2015
version 3.0.0.0
Posted - 06/24/2016 :  20:13:08  Show Profile  Reply with Quote
Your software is a wrong version.
Download the latest software 7.09 from following link:
http://www.mcumall.com/downloads/download.asp?DownloadID=57
freebandjunkie
Posted - 06/24/2016 :  20:55:32  Show Profile  Reply with Quote
okay now its recognizing the programmer.. my chip says " S93C6 6DV42 6197 " how do i find this device? when i begin typing it into the search it only brings up " S93C66D "
thanks for the help
Posted - 06/24/2016 :  21:06:15  Show Profile  Reply with Quote
Try to read it with S93C66D, and see what happens.
freebandjunkie
Posted - 06/24/2016 :  22:21:49  Show Profile  Reply with Quote
im getting
ID check skipped
Reading... Buffer
Elapsed time: 0.13 seconds
Read completed.
but its not pulling any info from the chip. the buffer tab is blank no data filled in. i tried all the different speeds also and still nothing
Posted - 06/24/2016 :  23:06:27  Show Profile  Reply with Quote
Do you know if any other people can work this way?
The in circuit programming is tricky. If you connect the programmer direct to your board, then that mans to let programmer to power your entire board. But the programmer only be designed to power a single chip.
I know in many cases, your target board need to be powered up and then only connect programmer signal lines to the board. The target chip should be powered by the board, not the programmer.
freebandjunkie
Posted - 06/25/2016 :  06:58:53  Show Profile  Reply with Quote
well the thing is locally nobody wants to give up any ' trade secrets ' so im sort of at the mercy of the internet.
i see, so would it be a good idea to maybe buy the power cable to the gq programmer? could it be that the usb wire isn't carrying enough power?
what type of methods could i look into to power the board?
i've seen schematics to clusters and i notice they have 12v pins and a ground pin.. also i notice the cable from my test clips fit perfect on the pins on the cluster
freebandjunkie
Posted - 06/25/2016 :  07:04:50  Show Profile  Reply with Quote
thank you so much for the pointers youve provided also, although i havent achieved my goal just yet youve me feeling very optimistic
one more question: can you elaborate on " only connecting programmer signal lines " ?
Posted - 06/25/2016 :  11:22:45  Show Profile  Reply with Quote
On your clip disconnect the positive of the IC. Use an external power supply to power up your cluster.
