 GQ4X4 AM29F033C
Pikmin
Posted - 08/31/2016 :  18:34:32  Show Profile  Reply with Quote
I've been having a lot of issues with my programmer.
One day I can write the chips, the next day I can't verify those same chips...
I've tried using power, using another adapter, using another USB cable, Win 7,8.1 and Win 10.
When it does work I can only ever use the default +2 speed to erase the chip properly.
If i try to erase on lower speeds it starts but then fails and says chip doesn't need erase or not compatible
I'm beginning to think it might be the programmer, any advice?
Ready
GQ-4x4 1.0 @ SW Re. 7.09
USB Driver Re.1.0
Software Re. 7.09
Serial #: XXXXXXXXXXXX
Configuration OK!
<<AM29F032B*TSOP40>>
ID check failed.("04D4")
Please check device type, chip's orientation and pin contact.
Some OEM chips may have compatible chip ID
Continue?
Yes
ID check skipped
Erasing...
Elapsed time: 34.73 seconds.
Erase completed.
Continue?
Yes
ID check skipped
Blank checking... Buffer
Elapsed time: 117.79 seconds.
Chip is blank
Continue?
Yes
ID check skipped
Writing... Buffer
Elapsed time: 0.00 seconds.
Write failed, Address=0x000000, Buffer=0xC2 Device=0xFF
Write failed
Posted - 09/01/2016 :  21:15:14  Show Profile  Reply with Quote
If your ID check failed, then you should not do other things.
You need to solve the ID error issue.
Most of ID issues are caused by poor pin contacting.
Using a magnify glass to check each pin in ZIF socket.
Pikmin
Posted - 09/01/2016 :  23:55:15  Show Profile  Reply with Quote
It's normal for that chip to fail the ID, uses AM29032B
I just haven't bothered to create another device with the 04D4 ID
I've wrote these chips successfully in the past.
The local supplier will send me another programmer to test and I will return the one I have
Generated in 0.3 sec. Snitz Forums 2000
