 GQ-5X Testing
GOLEAN
Posted - 01/13/2017 :  12:27:04  Show Profile
Is there a method to test if the GQ-5X is functioning properly. We are experiencing inconsistent programming and intermittent operation of the GQ-5X. Thank you for any input
SI
eduardo48
Argentina
Posted - 01/14/2017 :  20:28:00  Show Profile
Hi, I use the programmer from version 1.
The soft works better from that version, I think it needs improvement.
I use programming nand tv, I have acceptable results.
The memories nand is a theme, and more used in tv.
 If you write in nand without bad sectors go perfect, the problem jumps when there are bad sectors, some tv ok, but others cause problems.
Generated in 0.29 sec. Snitz Forums 2000
