 W25Q128BV & W25Q128FV
foxhunt888
Posted - 03/29/2017 :  19:29:44  Show Profile
I have the GQ 4x4 with the adp-098
The list of supported devices listed is the WinBond 25q128FV
The device I'm trying to work with is the WinBond W25Q128BV and it is not listed.
The only difference between the 2 that the W25Q128FVSIG has the /reset input on pin 3
The device ID detected for the W25Q128BV is the same as the W25Q128FVSIG.
I should be able to use the device option W25Q128FVSIG to program the W25Q128BVFG, correct?
Thanks in advance!
Posted - 03/30/2017 :  03:33:32  Show Profile
The only differences between the 2 devices is that the W25Q128FVSIG has the /reset input on pin 3 and the package is not the same!
SOIC-8 208mil VS SOIC-16 300mil.
Yes, it will work since you have the right adapter and can correctly read the chip's JEDEC ID code.
Edited by - anniel on 03/30/2017 03:36:51
foxhunt888
Posted - 03/30/2017 :  03:36:09  Show Profile
Thanks Anniel!
Posted - 03/30/2017 :  03:37:56  Show Profile
Good programming!
supervizeur
Posted - 03/31/2017 :  10:33:14  Show Profile
Thank you Anniel!
Posted - 05/23/2017 :  10:24:39  Show Profile
Glad I could be of assistance.
