 k9F1G08U0D
marck3
Brazil
Posted - 03/01/2017 :  09:34:09  Show Profile
I have a problem recording nand and flash tv samsung ln40D550k, I can not make a copy of this. I've tried several metrics, like versions 1.05, 1.06 and 1.07 the last. I tried at several speed(9) and got close, but on TV the logo was rebooted. The memory is k9F1G08U0D, the strange one that records everything right. In the verification all ok, but on tv does not work. And as it was found in the otp region. Or the speed of recording or reading the gq-5x. The tn5000 recorder for example works with the speed of 0.4mhz, 2mhz, 4mhz and 8mhz no max.
Edited by - marck3 on 03/01/2017 14:44:16
marck3
Brazil
Posted - 03/01/2017 :  15:46:18  Show Profile
Nand memory K9F1G08U0D only works the TV itself.If I try to copy it in another, it does not work.But if I reuse the TV's own chip, this is to erase it and rewrite it works 100%.
But if I use a new chip it records but TV does not work.It gives the impression that it is missing to record some region of the chip. Another thing is that the check always works ok, but it does not work.
Sorry for the English, because it has been translated.
GQ5XSupport
Posted - 03/02/2017 :  22:38:53  Show Profile
Your new chip has different bad block. You need to use smart copy to calculate the bad block.
marck3
Brazil
Posted - 03/04/2017 :  14:25:27  Show Profile
Yes I had 2 badblock I did exactly as you teach. At speed 9 it records but on TV restarting.
In other brands record blz, but in sansung has something missing.
MANN France
France
Posted - 03/31/2017 :  03:53:14  Show Profile
bonjour , voici un problème semblable avec les mémoires SAMSUNG (16 Gbits) des UExxD5700 , avec le vôtre LE xx D550 ( 1 Gbits) =
voir sur forum = http://www.mcumall.com/forum/forum.asp?FORUM_ID=13
Clone failure K9GAG08U0E. =
voici mon mail d'aujourd'hui , en rèponse au support produit =
Bonjour ,
Votre vidéo utilise une NAND cible qui n'a pas de "bad block" .
Je procède de même façon que votre vidéo ( version 1.06), mais les NANDS que je reçoit ont toutes des "bad block" d'origine .vous envoyer une vidéo n'a aucun intérêt.
je vous ai envoyé des recopies d'écran avec des échecs de vérification. ( version 1.07) ( messages Ebay)
la seule vérification qui marche est celle de la source et sa lecture en fichier binaire sur le disque dur ( et c'est heureux !!)
Votre logiciel 1.07 ne fonctionne pas avec des NAND qui ont des bad block en source ET en cible .
ce sont des K9GAGO8U0E-SCBO qui équipent les "smart TV" Samsung séries UExxD5700 et 5500. ( cartes mères BN41_01660 et BN41_01747)
Si les NAND étaient des K9GAGO8U0E-SCSO, le logiciel fonctionnerait , car elle n'auraient pas de bad block de fabrication. En effet SAMSUNG trie ses mémoires à la fabrication , avant de les vendre !! ( et à un prix , bien plus cher que ses "rebuts" , écoulés dans le marché et sur ses TV).
Si la mémoire a plus d'un seul bad block , il y a de fortes chances que la TV aura des problème en cours d'utilisation.( cela peut fonctionner des années , mais un jour , cela cesse, sans cause apparente . la TV reboucle indéfiniment avec apparition du logo "Smart TV" au démarrage . la télécommande n'agit plus , et il faut changer la carte mère , qui n'est plus fabriquée !! )
En conséquence , si vous m'améliorez pas votre logiciel , je , je me serais obligé de vous demander le renvoi de votre programmateur et le remboursement d'EBay. ( frais de retour , pris en charge par PAY PAL)
le titre de votre annonce précise clairement qu'il prends en charge les K9GAGO8U0E sans préciser l'extension = -SCBO ou SCSO ( voir datasheet SAMSUNG) .
voir aussi http://www.mcumall.com/forum/topic.asp?TOPIC_ID=7819
je vous joins en P.J des recopies d'écran ( voir mes messages sur Ebay = PB d'envoi de photos = souvent erreur serveur !! )
Oui le S signifie qu'il n'y a aucun bad block lors de la fabrication (ça reste à voir si ça existe réellement ailleurs qu'en contrefaçons Chinoise) mais inévitablement des bad blocks apparaissent à l'usage de là le "Garbage
Collection" et le "Wear Leveling" des Flash.
14. Customer Bad Block
B : Include Bad Block
D : Daisychain Sample
K : Special Handling
L : 1~5 Bad Block
N : ini. 0 blk, add. 10 blk
S : All Good Block
0 : NONE (Containing Wafer, CHIP, BIZ, Exception
handling code)
Si le firmware de la TV n'est pas modifié la corruption réapparaitra de toute façon.
d'accord avec anniel
il y a un problème dans le logiciel de ces TV ( et SAMSUNG se garde bien de le rectifier = son intérêt est que les TV tombent en panne après la garantie , pour en vendre de nouveaux= "obsolescence programmée" .=> arnaque à la consommation , par "vice caché" =>action judiciaire possible en FRANCE , contre SAMSUNG )
Quand aux contrefaçons , ce n'est pas sûr , mais revente des rebuts de fabrication après tri , j'en suis maintenant persuadé .
mais si j'ai achète votre programmateur , c'est pour qu'il fonctionne correctement , bad block ou pas !!!
CQFD
---- Message d'origine ----
De : support@mcumall.com
À : superphenix@numericable.fr
Objet : Re: photo QG-5X
Date : 31/03/2017 06:47:33 CEST
Checked with engineer, and I was told your may no followed the steps in the video.
Please make sure you followed the steps in following video.
https://www.youtube.com/watch?v=7KTYrj_pgbA&t=40s
If it still does not work, then record your software video and let us to check.
Thank you.
Regards.
cdt jean pierrre MANN 33170 GRADIGNAN / Bordeaux . France métropolitaine
(00) (33) (0) 6 58 45 08 72
supervizeur
Posted - 06/12/2017 :  08:51:10  Show Profile
Just curious, what does cdt stand for?
Edited by - supervizeur on 06/12/2017 08:51:55
Posted - 06/15/2017 :  18:12:55  Show Profile
Central Daylight Time
Cheval de Troie
Castellón–Costa Azahar Airport
Clock Drawing Test
Causal Decision Theory
Causal Dynamical Triangulation
CycloDodecaTriene
Center for Democracy and Technology
Cytolethal Distending Toxin
Carbohydrate Deficient Transferrin
CommanDanT
Continental Divide Trail
Current Dental Terminology
Constrained Delaunay Triangulation
Children's Dance Theatre
Clostridium Difficile Toxin
You decide.
supervizeur
Posted - 06/20/2017 :  04:00:07  Show Profile
Cheval de Troie
Clock Drawing Test
CycloDodecaTriene
CommanDanT
You decide.
The "D" must stand for "Deficient".
Posted - 06/27/2017 :  10:48:06  Show Profile
Cheval de Troie
Clock Drawing Test
CycloDodecaTriene
CommanDanT
You decide.
supervizeur
Posted - 07/09/2017 :  09:07:32  Show Profile
Cheval de Troie
Clock Drawing Test
CycloDodecaTriene
CommanDanT
You decide.
Posted - 07/13/2017 :  07:15:13  Show Profile
Cheval de Troie
Clock Drawing Test
CycloDodecaTriene
CommanDanT
You decide.
I love those Zero drawings.
