 How to read N70005FWCHCA
jc179
Posted - 07/03/2018 :  09:20:21  Show Profile
Any idea how to read N70005FWCHCA ?
Is an Intel chip, have tried reading as a 28F512 with no luck.
Any ideas?
thanks,
Jonathan
Posted - 07/03/2018 :  12:01:46  Show Profile
Any ideas?
thanks,
Jonathan
Datasheet?
Posted - 07/03/2018 :  12:18:25  Show Profile
Any ideas?
thanks,
Jonathan
Datasheet?
Never mind, try 28F010.
jc179
Posted - 07/04/2018 :  12:59:53  Show Profile
Ah doh. Will try that and report back!
thanks,
Jonathan
Posted - 07/04/2018 :  14:24:37  Show Profile
thanks,
Jonathan
You're welcome.
jc179
Posted - 07/04/2018 :  18:00:10  Show Profile
Hey Anniel
No luck, get the same thing - when I try to read it just 00 00 00 etc.
Any others I can try?
I am using the PLCC32 to DIP 32 adapter, and as noted have the chip pin #1 in GQ4X at pin #5 per the picture.
Jonathan
Posted - 07/05/2018 :  14:13:28  Show Profile
Hey Anniel
Jonathan
Can you get the ID?
jc179
Posted - 07/06/2018 :  06:20:05  Show Profile
No, get ID fails too.
Maybe another chip I need to send to ZLM...
I recall reading there was something special about this chip and reading it in a eeprom, but I haven't been able to find that...
jc179
Posted - 07/11/2018 :  10:34:37  Show Profile
Any other ideas Anniel or ZLM ?
Posted - 07/16/2018 :  13:16:48  Show Profile
Pins are clean? No conformal coating residue?
Posted - 07/16/2018 :  13:20:45  Show Profile
Flipped pinout? Verify on your PCB for power pins if it matches the 28F010 Datasheet.
jc179
Posted - 07/19/2018 :  05:14:37  Show Profile
No conformal coating residue, chip works in socketed ECU ok, just not GQ 4X.
Will check the power pins on PCB with a meter and report back if they match the same as the 28F010 datasheet.
Jonathan
Posted - 07/20/2018 :  08:52:18  Show Profile
Jonathan
Yes, the pinout could be different.
Generated in 0.44 sec. Snitz Forums 2000
