 PM25LV010 incorrectly ID-d
khaahk
Posted - 02/16/2013 :  06:36:08  Show Profile  Reply with Quote
Hi!
This might be a software bug:
SETUP:
PM25LV010 - adapter ADP-004 - GQ-4X software 6.21 - Windows xp pro 32b
If i select the correct chip (that is PM25LV010) then the chip gets id-d as FFFFFF
32.12 KB
If i select the W25X10 chip, then the PM25LV010 gets id-d correctly.
(7F9D7C)
The program reads it correctly also - but says the id does not match.
33.54 KB
Posted - 02/17/2013 :  22:49:13  Show Profile  Reply with Quote
Can you ignore the ID warrning and try to read/write the chip?
Naughty
India
Posted - 02/25/2013 :  07:46:18  Show Profile  Reply with Quote
i am having the same Problum & i buy my new GQ-4x Programmer a few Days Ago....is there a solution for it or i can just ignore the ID Check Warning for now ?
Do Searching before Asking, But Asking will never kill you......
Posted - 02/26/2013 :  10:00:44  Show Profile  Reply with Quote
I think your software is not latest. Download the latest sftware and see if the ID correct.
khaahk
Posted - 02/28/2013 :  02:12:45  Show Profile  Reply with Quote
Even if chip gets ID-d as FFFFFF, it still reads, erases and writes ok. Tried software 6.16 and 6.21, two different computers. Both XP though.
Posted - 02/28/2013 :  21:43:07  Show Profile  Reply with Quote
I think there is a software bug on this chip ID procedure.
sadpony
Posted - 02/08/2019 :  10:01:48  Show Profile  Reply with Quote
To fix:
edit c:\Program Files (x86)\ GQ USB Programmer\devices.txt
Search for: PM25LV010
Then in the line with PM25LV010, replace Class="AT25FS010" with Class="W25X10"
Save and done! Should ID correctly now.
Posted - 02/08/2019 :  10:47:04  Show Profile  Reply with Quote
Originally posted by sadpony
To fix:
Good advice but kind of late. Is the bug still present in the latest versions?
