 RH86 eprom ecu Toyota Hilux
Pablo Labrune
Argentina
Posted - 03/17/2019 :  11:04:27  Show Profile
Good afternoon, would like to know if the RH86 memory can be recorded as 93C86 16 bit? I have a GQ4X.
Although you can read it as 93C86, I would like to be sure that I am doing the right thing. I could not record it again with another dump, if I allowed to put everything in FF or this memory is damaged.
Thank you
Download Attachment:
1084846
Posted - 03/17/2019 :  12:08:51  Show Profile
Thank you
1084846
What do you mean by you could not record it again with another dump? Why would that be?
Or allowed to put everything in FF? That's ok it would be a blank chip.
And why would it be damaged? It uses the same voltages as a 93C86.
Pablo Labrune
Argentina
Posted - 03/18/2019 :  03:55:29  Show Profile
Good day, if it is strange that I can record FF because I read it again and it is blank but when I want to record the new one I record it badly. I'm waiting for the new memories to arrive.
Then I will comment when I try the new memories.
Is it correct to read it as 93C86?
Tanks
Posted - 03/18/2019 :  08:10:06  Show Profile
Tanks
Yes, 16b.
Pablo Labrune
Argentina
Posted - 04/10/2019 :  05:15:01  Show Profile
Good morning, to close the topic commented that it worked perfectly memory 93C86 16bit as a replacement for the RH86.
Thanks everyone for your help.
Posted - 04/10/2019 :  06:30:43  Show Profile
You're welcome and thank you for your feedback.
