 ST M27C256B not reading in TL866II?
Calab
Canada
Posted - 07/08/2022 :  14:21:23  Show Profile
I recently purchased five ST M27C256B EPROMs on eBay. Now I am trying to use one, but when I try to read it, or verify that it's blank I get a Check ID error.
I am using XGPro v12.05 and a TL866II-Plus v 04.02.129 EPROM burner on a Windows 11 PC. This combination has worked before, but I've recently wiped my system and did a fresh installation of Windows and XGPro.
I have selected the correct chip in the software. The chip is in the socket correctly. Device manager in Windows looks OK.
When I try to read or blank check the chip, the ID that I see is 0x0800. If I skip the ID check and do a read, the chip is full of "F8".
I do have a second chip in my EPROM eraser, but I don't think that it's going to help.
Is it possible that the XGPro software is damaged, or the EPROM burner itself is not working correctly? Is there anything I can do the check this?
Posted - 07/09/2022 :  06:20:22  Show Profile
Ask the manufacturer, they certainly can help you.
Calab
Canada
Posted - 07/10/2022 :  09:01:18  Show Profile
Just to follow up...
I did some testing on these chips, and others that I have and have determined that my EPROM burners are working properly. I just received "fake" EPROMs.
I was able to burn a M27512 for my purposes.
Posted - 07/10/2022 :  14:55:24  Show Profile
Fakes are common since they are long time obsolete chips.
Generated in 1.1 sec. Snitz Forums 2000
