 25VQ40ATIG support on GQ-4x4
mac_ha
Vietnam
Posted - 10/28/2024 :  23:23:41  Show Profile  Reply with Quote
Hello, is it possible to read/write to 25VQ40ATIG chip on GQ-4x4 True USB Willem programmer? I don't see this chip on the devices list, but maybe some other chips are compatible? I cannot find the datasheet for 25VQ40ATIG, though, so can not be sure if any of different 25Q40 chips are compatible? Any help would be very much appreciated. Thank you.
Posted - 10/29/2024 :  11:14:13  Show Profile  Reply with Quote
Would it be similar to this one?
uploaded/anniel/20241029121223Zbit ZB25VQ80 3V 8M-BIT SERIAL NOR FLASH WITH DUAL AND QUAD SPI Preliminary Datasheet.pdf
mac_ha
Vietnam
Posted - 11/04/2024 :  04:57:33  Show Profile  Reply with Quote
[/quote]
[/quote]
Thank you for the reply, I was also able to find this datasheet:
https://xonstorage.blob.core.windows.net/pdf/zbitsemi_zb25vq40atig_xonjuly20_20_link.pdf
The question is, would the GQ-4x4 be able to program it? Which device should I select?
Posted - 11/04/2024 :  08:36:31  Show Profile  Reply with Quote
[/quote]
[/quote]
W25Q40EW
mac_ha
Vietnam
Posted - 11/05/2024 :  10:19:12  Show Profile  Reply with Quote
W25Q40EW
The W25Q40EW is a 1.8V part, I've measured in-circuit Vcc of my part as 3.3V. I tried the W25Q40CL, the chip was detected as Exar, but then read failed...
So I've just submitted, via GQ Application, a request to add a new chip. Hopefully it won't be too long?...
