 Unable to burn 27cxxx
gkoutsis
Posted - 09/22/2005 :  05:30:03  Show Profile
I got the enhanced USB powered programmer.
I can read and verify all my eeproms (27c64,27c256 and 27c512) but by the time I try to write them (yes they are empty and all check out with the blank test) I get an error after the first bit. Sometimes they seem to program and fail at the last bit but the chips are still empty after the "programming".
yes, I've tried all the different setting in my BIOS and on 3 different PCs.
I am out of ideas here....
backbiter17
Slovenia
Posted - 09/23/2005 :  09:52:36  Show Profile
i think your (& my) programer does NOT support those chips
br, ales
usb
Posted - 09/27/2005 :  14:39:00  Show Profile
Read and then Verify a chip does not means the programmer been working correctly. That because the software does not verify the hardware jumper/DIP setting before read/verify.
You still need check following points:
-Chip's location and orientation in ZIF.
-DIP switch setting.
-Blank check chip before doing write.
firyembers
Posted - 10/19/2005 :  07:49:31  Show Profile
Hi
I purchased one of these (PRG 001) April 2005,and have been well pleased with it,it does burn 27xx series as per instructions provided with the kit.
1.Verify the eprom is empty,leaving it in the UV eraser a longer time(i found the erase times differ from even the same manufacture even brand new)if after one time if does not verify empty.
2.Remove the jumper above the ZIF socket and press once the button to the right of the jumper,this sets the voltage to 15v.The 27xx is 12v proram.
Now you are ready to program.
When finished,replace the jumper(You will see the 15v led go off and the left led go on(the jumper is a safety feature and resets the voltage so as to not damage flash eeprom's)
regards
G
