 Pal Problems
crusader
Posted - 05/10/2009 :  08:14:03  Show Profile
Hi all,I bought a top 2049 for programming eprom and gal but, if i programming or erasing the palce16v8h-25 i have some problems, for example just select the chip gives me "no bit find file" and if I try to erase I answered "0000001000000010000000100000001000000010000000100000001000000010
Error at: L0000
Blank Error at ...: 00000 (00) "
there is a solution to solve?
Thank you and hello
tinhead
Germany
Posted - 05/28/2009 :  11:55:24  Show Profile
check with the newest software version, h**p://www.top2048.com/gb/tops/topwin5.exe
it is 5.75 ( 5.72 had some pal/gal fix implemented )
crusader
Posted - 06/07/2009 :  08:47:32  Show Profile
OK, I had seen that had come out a new version, I installed the new version, the v5.78, and finally I have the full support to palce16v8h, now the law and program well.
5.73 was the version that did not work well.
hello and thanks
Edited by - crusader on 06/07/2009 08:50:19
simeon
Posted - 06/08/2009 :  14:15:57  Show Profile
use usb 1.1 12mbps or usb 1.1 by using usb 1.1 hub
between the programmer and pc etc
this way forces usb 480kbps port to only use 12mbps
as coms to top usb programmer
p5b asus main machine
legacy detection enabled
