 Programmer for 49LF040 and 39SF020.
jibanes
Posted - 10/05/2009 :  15:54:54  Show Profile
Hello,
Which programmer should I use for the following Eeproms:
* 49LF040B
* 39SF020A
As you have guessed, they are PC bioses, is it possible to just feed the programming software with the .bin file?
I do not have a parallel port, therefore, whichever programmer you recommend would have to be either serial or usb. Preferably, I would also like a ZIF socket for these Eeproms (on the programmer).
Finally, do you recommend any particular "extractor tool?", do you sell any?
Sincerely,
Jerome
Edited by - jibanes on 10/06/2009 10:47:11
Posted - 10/06/2009 :  13:57:25  Show Profile
The GQ-4X or GQ-3X will work on those chips.
If your chip is in DIP package, then you do not need any adapterd. Other wise you may need adapters for your chip.
"extractor tool"from PCB? SMD Reworkstation will work.
jibanes
Posted - 10/06/2009 :  16:04:59  Show Profile
Thank you I have just ordered GQ-4X (Full Kit).
J.
Generated in 0.46 sec. Snitz Forums 2000
