 i'm new and i just ordered GQ-4X
benaknoun
Spain
Posted - 05/26/2010 :  14:44:32  Show Profile
Hi, i have finally ordered my very first universal programmer GQ-4X, i cant wait to receive it, sorry i am new in this field and i have a couple of questions:
- i need to read a 25C160 SPI EPROM chip from a car radio, i know this programmer supports this chip but do i have to remove the chip from the board or can i do it on-board? do i need any adapters
and also, is it easy to do this ? in general.
Posted - 05/26/2010 :  22:23:38  Show Profile
If your board has a SPI port for programming, then you do not need to remove it.
But if not, then you can try to use the test clip to program it, but that needs some try.
Remove the chip and program it on the programmer is the best.
benaknoun
Spain
Posted - 05/28/2010 :  06:45:49  Show Profile
Hi, thank you for your reply.
how do i know if my board has a SPI port for programming?
also, i removed the chip and damaged the board OF COURSE ( 1st time..) but the chip is still ok, however, it is tiny and it doesn't fit properly on the programme.
can you help please?
shall i post pictures?
thanks
Posted - 05/28/2010 :  09:25:21  Show Profile
"damaged the board" ??
I think you did not use a good tool to remove the chip. If you use rework station, you will never damaged the board.
Picture will help.
benaknoun
Spain
Posted - 05/28/2010 :  10:47:39  Show Profile
Hi, do you sell rework station? and which one do you recommend for a beginner?
i tried posting pictures but doesn't go through, shall i upload them or insert image?
it says http not allowed??
thanks
Posted - 05/30/2010 :  19:39:35  Show Profile
use "insert image"
Do not let Speace and any other special char in the image file name. Only letter and number.
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=4432
benaknoun
Spain
Posted - 06/07/2010 :  14:34:40  Show Profile
Hi, i have tried to order a rework station but due to the weight of the item, delivery is not available to UK, so i cant buy it from you unfortunately...
Posted - 06/10/2010 :  16:15:51  Show Profile
contact order@mcumall.com for shipping rate.
