Check eprom condition
Haxxer
Posted - 07/01/2010 : 05:35:30
Hi!
If I verify a eprom in USBPrg, can I be 100% sure that it will work?
I suppose the whole eprom is tested?
Posted - 07/01/2010 : 09:41:09
If the EPROM passed write and verification, then the EPROM is considered programmed successfully. It should work correctly.
Haxxer
Posted - 07/01/2010 : 10:46:32
Sounds good.
I will sell some programmed tuning chips to a company, but there are no need to test them in the ecu before sale or?
Posted - 07/01/2010 : 12:18:01
No.
Or you can jus test one chip to confirm you programmed a correct data file.
Haxxer
Posted - 07/02/2010 : 02:35:42
Ok, thanks for the info.
Generated in 0.17 sec.
