 Checksum?
BabyScientist
Posted - 03/12/2011 :  11:24:20  Show Profile
How do I get the checksum after reading a chip? I don't see any option for this.
BabyScientist
Posted - 03/16/2011 :  09:38:00  Show Profile
For example I am told the checksum for the chip is supposed to be E4F6 ... How do I see the checksum after reading to make sure it is E4F6?
BabyScientist
Posted - 03/16/2011 :  10:52:49  Show Profile
OOps I am using a very small netbook screen I did not see the checksum on the bottom of the GQUSB terminal!
Now another question---checksum for this chip in GQUSB shows 000FF856, it is supposed to be E4F6... Checksums for all other chips also do not match. But chips work ok. I think it is reading wrong--can you advise? How can I verify checksums correctly?
Posted - 03/18/2011 :  11:04:48  Show Profile
GQUSB uses standard checksum calculation.
The displayed checksum is the acture checksum from chip.
If the duplicated chip is working fine, then the checksum should be fine.
