 fuse errors
Beerwolf
Posted - 05/13/2011 :  07:49:11  Show Profile
Is anyone out there any good at troubleshooting a hex code that gives fuse errors. I have a lighting project I did with a pic18f20k25. The project came with a hex file and I got the website to reluctantly give me a second hex file. both give a fuse error. Different lines, but the same code sequence in those lines. I have a feeling it is a fuse setting but I can't get any support from the website that put the code out.
Here is the project:
h**p://electronics-lab.com/projects/motor_light/025/index.html
The hex code is available at the website. I think it's the third line from the bottom:
:0300010006190ECF
gives a fuse error.
Any help would be greatly appreciated since I'm already $50 into this project.
ICSG
Posted - 10/24/2011 :  06:20:46  Show Profile
Not sure if this is the same problem, but I had a similar issue with the PRG-017 and a PIC18.
http://www.mcumall.com/forum/topic.asp?TOPIC_ID=2101
