 Problems using the MCUMall 16bit adapter - Solved
jensmaa
Germany
Posted - 01/09/2013 :  04:33:42  Show Profile
Hey folks!
Since I failed miserably with this adaptor... http://www.mcumall.com/forum/topic.asp?TOPIC_ID=4997
...I bought a MCUMall 16bit adaptor. Unfortunatly I still can't manage to burn the eprom :(
I attached some pictures:
The adaptor:
http://www.jensma.de/upload/files/hW01Y6pL__DSC_0585.jpg
The adress wires connected to the programmer:
http://www.jensma.de/upload/files/I654mYVb__DSC_0587.jpg
The adress wires connected to the adaptor:
http://www.jensma.de/upload/files/ZnsgUAQv__DSC_0588.jpg
I've got a wall wart connected with ~12V:
http://www.jensma.de/upload/files/Y5Mhsw5u__DSC_0592.jpg
The programmer:
http://www.jensma.de/upload/files/onTsdbkE__DSC_0589.jpg
Any help is much appreciated :)
With the jumper next to the dipf and p1 connected, everything worked after re-erasing the eprom :)
Edited by - jensmaa on 01/09/2013 05:37:09
jensmaa
Germany
Posted - 01/09/2013 :  04:38:49  Show Profile
Ah, I forgot to jumper J3, right beside the dip switches. Testing now with jumper set. If you notice any other mistakes, don't hesitet to answer :)
jensmaa
Germany
Posted - 01/09/2013 :  04:44:06  Show Profile
Well, with the jumper set, the first bytes (aborting at 0x00E8BF right now) are written successfully then the process is aborted. Any ideas :(?
I connected P1 too, it's still failing.
Edited by - jensmaa on 01/09/2013 05:05:02
Posted - 01/18/2013 :  21:29:42  Show Profile
Try to change V3/V4 on adapter.
jensmaa
Germany
Posted - 01/31/2013 :  11:51:21  Show Profile
Worked like a charm, thank you :)
