Programmer for car ECU
Dimitrios
Greece
Posted - 06/15/2013 : 01:00:30
Hello !I am about to buy a programmer.Truth is I am not really into this.
I currently flash cars via obd2 so I am really really confused.
Your programmer does a lot eeprom/flash that I already work but what other adapters would I need ?
benaknoun
Spain
Posted - 06/15/2013 : 18:00:23
Hi
It depends on the IC's you work on, there are different adapters for different IC
Dimitrios
Greece
Posted - 06/17/2013 : 06:13:51
Sorry I didnt ask the question properly.
I found what I wanted here
http://www.mcumall.com/support/EpromApplicationList.pdf
I wanted a list so I can compare what your programmer supports :) thank you again
benaknoun
Spain
Posted - 06/17/2013 : 14:55:16
I have the GQ-4X and it's good, but better check if it supports the chips you will be working on..
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=4312
Generated in 0.17 sec.
