 Top & SST Flash
Escher
Posted - 10/22/2006 :  13:33:45  Show Profile
Hi, i have got a TOP 2005 programmer and i can try to program the 39SF040 SST FLASH but it doesn't very stable.While i program the flash and i move the window's topwin it crash,
Is there a solution ?
Thanks....
Posted - 10/23/2006 :  12:11:31  Show Profile
The TOP programmer software uses PC's CPU to do the part of the write job. Moving arround window while writing will interrupt the write process. So, you'd better let it finished job before you moving the software window.
rcpax
Posted - 10/27/2006 :  19:32:25  Show Profile
Hi escher, I just programmed an SST 39SF040 successfully. Make sure you have the latest TopWin program (v2.21). And as ZLM said, when it programs, don't do anything with your computer. SST chips program slowly, so please be a little patient.
http://paxtech.blogspot.com
Generated in 0.76 sec. Snitz Forums 2000
