 GQ 4x4 Help
Seer
Posted - 09/05/2019 :  04:38:54  Show Profile
I have seen a few posts about this burner but i have tried several things and cannot get the burner to do a blank check it fails.
I am able to read the original chip but when I try to burn it this comes up: Write Failed, Address=0x000001, Buffer=0xFD Device=0x1C
This is the same error when trying to verify it is blank as well.
The last burner I used was 20 years ago and called a Gangpro 8 but this seemed to be a good way to program 42 pin eproms
Posted - 09/05/2019 :  13:40:19  Show Profile
Are you certain your device is blank?
Seer
Posted - 09/06/2019 :  13:41:42  Show Profile
Yes I ran 4 of them through the eraser
Posted - 09/06/2019 :  14:19:39  Show Profile
Are you certain they are good?
