 Tsop48 29f016
Icelvlan8866
Posted - 03/28/2020 :  12:24:46  Show Profile  Reply with Quote
Hello,
Trying to program a tsop48 29f016.
Does someone know the code I need to enter in the device file?
I'm getting a consistent ID and am able to read. When I write, it does write some stuff, but gives me an error at the end. This is on -2.
Name="M29F016A*TSOP40",ID="4320",Class="29F040B",Category="FLASH",MFG="FUJITSU",CodeSize="2097152",DIP="100011110101",Adapter="TSOP40B-DIP32";
This is what I put in so far.
Icelvlan8866
Posted - 03/28/2020 :  12:56:54  Show Profile  Reply with Quote
I also tried to bend back pin 1,2,23,24,25,26,47,48 so that they don't make contact with the adapter and they are th exact same pinout as 29f016 tsop40 and still nothing.
When I try to erase, it says "Erase failed, function not supported on device or the chip does not need erase. But I can see there is something on it when reading.
Icelvlan8866
Posted - 04/07/2020 :  17:57:04  Show Profile  Reply with Quote
Bump.
Posted - 04/08/2020 :  11:40:26  Show Profile  Reply with Quote
Originally posted by Icelvlan8866
Hello,
When you read the data is it correct?
Posted - 04/08/2020 :  11:40:34  Show Profile  Reply with Quote
Try Fill Buffer Hex, Write and Read.
Posted - 04/08/2020 :  11:41:01  Show Profile  Reply with Quote
Bump.
Icelvlan8866
Posted - 04/09/2020 :  12:01:35  Show Profile  Reply with Quote
Sorry,
Can you clarify this?
Try Fill Buffer Hex, Write and Read. Change the hex in buffer and write?
Posted - 04/09/2020 :  12:35:43  Show Profile  Reply with Quote
Sorry,
Yes. Use the menu option "Fill Buffer Hex".
