 What adapters I needed on Willem programmer?
Posted - 08/30/2005 :  10:27:55  Show Profile
I'll work on following chips, what adapters I needed on a Dual Powered Willem programmer?
DiL 24/28/32 pin, PLCC 32 pin. PLCC 44 pin. Psop 44 pin
usb
Posted - 08/30/2005 :  10:29:53  Show Profile
For the most DIL 24/28/32 pin EPROM/Flash/EEPROM chips you do not need adapter.
For the PLCC32 chip you need a PLCC32-DIP32 or PLCC32 HUB/FW adapter depend on your chip type. (The Enhanced willem programmer has build in PLCC32 and HUB/FW adaper on board)
For the PLCC44, if your device is 16 bit EPROM, then you need a 16 bit EPROM adapter with PLCC44 adapter. OR if your chip is Atmel MCU PLCC44, then you need a MCS-51 adapter with a PLCC44 adapter.
Currently no PSOP44 ping adapter available in MCUmall.
Bianconi2
Brazil
Posted - 01/17/2006 :  21:37:19  Show Profile
BUT SOME ADAPTER PSOP 44, EXISTS THAT IT FUNCTIONS IN THE ENHANCED WILLEM PROGRAMMER ???? PLEASE.
THANK YOU
HERBER BIANCONI
BRAZIL
