 SEEQ 52B33-250
robertjhurst
Posted - 04/12/2023 :  01:44:11  Show Profile  Reply with Quote
Hi all, I'm trying to read the contents of the above to make a backup file, but can't find it on the list of devices.
I'm using a GQ-4X programmer.
There is a datasheet for the device here: h**p://www.limpulsion.fr/upload/docs/DM52B33H300.PDF
Can anybody advise how I might proceed?
Many thanks.
Edited by - robertjhurst on 04/12/2023 01:45:50
Posted - 04/12/2023 :  06:11:41  Show Profile  Reply with Quote
Many thanks.
Start with the 27C64 and drop VPP to 5V.
robertjhurst
Posted - 04/12/2023 :  23:12:52  Show Profile  Reply with Quote
Ok, thanks. I was trying to use a 27C64 as a drop in replacement as they are a lot more available. The machine wouldn't recognise it though so wanted to copy the prog across in case it needs a format.
What's the deal with Pin 1? Tied high on the 52B33, I've left it floating on the 27C64
Many thanks.
Posted - 04/13/2023 :  04:46:33  Show Profile  Reply with Quote
Many thanks.
Pin 1 on the 52B33 if low should erase all the chip.
