 Code 10
Maxxx
Posted - 10/25/2023 :  11:51:13  Show Profile  Reply with Quote
Hello I'm having trouble trying to get my GQ-4X4 to run on windows 7. I have finally gotten the drivers to load but I get "This device cannot start. (Code 10). I have uninstalled and reinstalled the drivers and the program and still it won't start.
Posted - 10/26/2023 :  06:25:52  Show Profile  Reply with Quote
You followed those instructions?
https://www.mcumall.com/forum/topic.asp?TOPIC_ID=7054
Maxxx
Posted - 10/26/2023 :  10:18:17  Show Profile  Reply with Quote
I have followed those instructions and the drivers have installed, but the program doesn't start. When I look in Device manager I can see the GQ Programmer in the USB list but it has a yellow triangle on it. When I click on the driver it says "This device cannot start. (Code 10)".
Edited by - Maxxx on 10/26/2023 11:26:21
Posted - 10/27/2023 :  08:09:21  Show Profile  Reply with Quote
Try another USB cable and another USB jack.
Maxxx
Posted - 10/27/2023 :  11:53:31  Show Profile  Reply with Quote
Hi anniel. I tried a different cable and jack but still had the problem, but I have fixed it. It was a mistake on my part, I had a chip in the burner every time I plugged the burner in and tried to start the program. Today I pulled the chip out of the burner plugged the burner into the USB jack the computer said it was loading drivers, after that I started the program and it worked. This is the first time I have tried to use a chip burner and I have a lot to learn. Thank you for your help!
Posted - 10/28/2023 :  06:36:37  Show Profile  Reply with Quote
