 need infor to add new chip to device list
gameromz
Posted - 07/23/2008 :  17:23:49  Show Profile  Reply with Quote
need info on adding a microcontroler pic 12f615 to the devices list, is this possible.
Posted - 07/23/2008 :  19:04:50  Show Profile  Reply with Quote
Try this line:
Name="PIC12F615",ID="29219",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="2048",Package="DIP8",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="",PRG_MODE="1",CFGByteLabel="- - - - BOREN1 BOREN0 IOSCFS CP MCLRE PWRTE WDTE FOSC2 FOSC1 FOSC0";
let me know if this works.
gameromz
Posted - 07/23/2008 :  19:58:53  Show Profile  Reply with Quote
will let you know, be 2-3 days before my chips get here.
gameromz
Posted - 07/28/2008 :  18:30:14  Show Profile  Reply with Quote
got my chips in today and id check fails
you had ID="29219" and it should be ID="29218"
after i change that it works.
Edited by - gameromz on 07/28/2008 18:57:28
gameromz
Posted - 07/28/2008 :  19:04:31  Show Profile  Reply with Quote
getting
VERIFY FAILED, ADDRESS=0x000000, Device=0x3f, Buffer=0x28
Posted - 07/30/2008 :  13:53:33  Show Profile  Reply with Quote
The ID should be "29218". Once you got the ID, then the basic communication between chip and the programmer setup is correctly.
Try this:
Name="PIC12F615",ID="29218",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="2048",Package="DIP8",Speed="5",BEGPRG_COMMAND="18",ENDPRG_COMMAND="A",BEGERASECHIP_COMMAND="9",PRG_MODE="1",CFGByteLabel="- - - - BOREN1 BOREN0 IOSCFS CP MCLRE PWRTE WDTE FOSC2 FOSC1 FOSC0";
How about slowdown the speed?
