 i need top853 vista driver...
vics9889
Posted - 08/25/2008 :  06:06:55  Show Profile
hi....i hav top853...i need vista driver for this..someone pls upload vista driver for me...thanks in advance...
vics9889
Posted - 08/25/2008 :  06:08:35  Show Profile
its really very frustrating for me with this vista driver problem...someone pls help me...
vics9889
Posted - 08/27/2008 :  07:15:45  Show Profile
pls someone reply me!!!
Posted - 08/27/2008 :  15:32:32  Show Profile
TOP853 has no driver for Vista.
dinesh.mbbs
India
Posted - 01/03/2009 :  03:24:17  Show Profile
hello ,
vics9889 i am also facing same problem , if u have got any solution , please mail me .
dinesh.mbbs
vics9889
Posted - 04/22/2009 :  00:19:41  Show Profile
Originally posted by dinesh.mbbs
hello ,
dinesh.mbbs
havnt got any solutions yet!!!
will let u no if i get solutions!!!!
by this time i use vmware to program eproms....
pls let me no if u get any solutions too...
tinhead
Germany
Posted - 04/22/2009 :  01:06:40  Show Profile
try what i have done with top2049 :
hxxp://www.mcumall.com/forum/topic.asp?TOPIC_ID=1993
as the driver is the same (windrvr6.sys) it should work, the top software is looking if drivers already installed on startup, so the manual way should work for all top2xxx and top853 - as they have exactly the same driver - only inf files have different names
tinhead
Germany
Posted - 04/22/2009 :  01:16:24  Show Profile
have just checked the top2049 software ( the newest version, which is already 5.71 ) - there is definitely device853.lst and in the exe itself the support for top853 is compiled ( at least was working in debuger to tell the software that my top2049 to act as top853 ) - and the software was working - so it should work with real top853 - just try it
simeon
Posted - 06/10/2009 :  07:06:55  Show Profile
if you use a top programmer via usb pre v3xxx
you need usb 1.1 hub in the middle
to force the port to use 12mbps
480mbps is no good
and screws up timmings
so follow advice as well as change software
top are so good to point this out
p5b asus main machine
legacy detection enabled
Edited by - simeon on 06/10/2009 07:07:26
vics9889
Posted - 11/04/2009 :  01:45:27  Show Profile
finally i found a solution....pls download & install topwin 6.10 version....it works 100% for me...here is the link h**p://rapidshare.com/files/302232524/topwin6.exe.html
i need post feed backs....
monahanz
Posted - 11/24/2009 :  01:13:51  Show Profile
I downloaded the above V6. I am using a TOP2004 on Windows 7.
Unlike previous versions it now loads the driver correctly and the green light comes on.
The install seems to go fine BUT when I click the desktop icon I get a dialog box
"Take off power, delay 5 sec, and then switch on". No idea what that means. I tried disconnecting the USB connection and even rebooting the computer.
Desperate at this stage. Any suggestions.
PS Tried Windows 7 "XP Compatability Box". Could not even load the driver!
monahanz
Posted - 12/07/2009 :  17:12:42  Show Profile
For anybody else having problems with TOP programmers. I gave up on the thing. I got (from China) a Wellon VP280. Came within a week! It came right up on Windows 7 solid as a rock. I's a 'no brainer'. Cannot believe all the time I spent screwing around with the TOP thing. Never again!
Generated in 0.58 sec. Snitz Forums 2000
