 Problem erasing AM29F010B
CZAR
Posted - 09/18/2008 :  15:46:47  Show Profile  Reply with Quote
I have a GQ-3X and i can't seem to erase this chip.Id checks is ok.
AM29F010B
I keep getting
Reading...Code Memory
Elapsed time: 0.80 seconds.
Read completed.
Erasing...
Elapsed time: 1.89 seconds.
Erase completed.
Blank checking...Code Memory
Elapsed time: 0.13 seconds.
Device blank check failed at address: 0x000000, Read= 0x00.
Blank check failed
Its a PLCC32 package chip & I am using the PLCC32-DIP32 Adapter.
I selected the AM29F010 from the device list.
I have several of these chips but have the same problem with them all.
Any idea why it cant erase it?
Edited by - CZAR on 09/18/2008 21:06:49
CZAR
Posted - 09/20/2008 :  11:58:13  Show Profile  Reply with Quote
199.04 KB
Posted - 09/21/2008 :  14:50:19  Show Profile  Reply with Quote
Try to use slower speed.
Try any other type of flash chips on PLCC32 adapter. This is to test the adapter.
If you are sure the chips and adapter are good, then you may need to send back the the programmer and chips for checking.
CZAR
Posted - 09/22/2008 :  05:18:04  Show Profile  Reply with Quote
Thanks for the advice.
I tried all speeds same results.
I also ordered another adapter and some new chips to test.
I also have problems iding this chip
W25X40AVDAIZ its a 8-DIP i have 15 new chips will not id any of them.
Edited by - CZAR on 09/22/2008 05:18:43
Posted - 09/22/2008 :  06:05:54  Show Profile  Reply with Quote
Try to use lower speed on 25X40.
If you are sure the chip orientation in ZIF socket is correct and you are using latest software Re 3.01B or later, then the programmer may need a check.
Please contact support@mcumall.com to arrange a return and exchange.
CZAR
Posted - 09/22/2008 :  12:53:31  Show Profile  Reply with Quote
Tried all speeds on the W25X40 no go.I am using ver 3.01B & also tried 3.02beta.
Just sent an email to support@mcumall.com will see what happens.
Thanks for your help
gzk
Posted - 10/01/2008 :  05:49:48  Show Profile  Reply with Quote
same problem with the am29F010 plcc32
CZAR
Posted - 10/17/2008 :  22:07:46  Show Profile  Reply with Quote
I sent my programmer back and they checked it out. Said it was working ok & the 3.03 beta version fixed the software bug on unlock of the 29F010 feature.
http://www.mcumall.com/download/TrueUSBWillem/GQUSBPrgRe3.03Beta.zip
It also IDs the 25X40 & 25x80 chips i could not ID b4.
I must say the sales and support people do a great job.
Edited by - CZAR on 10/17/2008 22:11:55
gzk
Posted - 11/28/2008 :  15:51:46  Show Profile  Reply with Quote
hi
i have still the same problem , i can't erase the am29F010 i'm using plcc32 32 adapter on the gq4X with the last software , before i used the gq3X and have same issue
how can i solve this issue ?
thanks
Posted - 11/28/2008 :  17:00:05  Show Profile  Reply with Quote
Can you ID the chip correctly?
Did you check if the chip sectors been locked up? and try to unlock it if so.
gzk
Posted - 11/30/2008 :  13:51:25  Show Profile  Reply with Quote
OK
it's work now
chip was protected
thanks
